Status
Not open for further replies.
1 - 12 of 12 Posts
2002 Volkswagen Passat Wagon GLX 4Motion
I've reached the end of my diagnostic rope for my 'new to me' 2002 V6 GLX 4mo wagon just will not start!
The car started and drove the first 30 miles or so of the trip home. Conked out on the highway, has not restarted since.
Fuel starved? I can 'light the engine' with starter fluid/ether.
VCDS-Lite
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine Labels: 078-907-551-ATQ.LBL
Controller: 3B0 907 551 CG
Component: 2.8L V6/5V G 0001
Coding: 07251
Shop #: WSC 05311
VCID: 6AA72EDD0567
WVWYH63B72E334897 VWZ7Z0A4505463
15 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-10 - - - Intermittent
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-10 - - - Intermittent
17585 - Bank2: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1177 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16543 - Oxygen (Lambda) Sensor B2 S2: Response too Slow
P0159 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
P0135 - 35-00 - -
Readiness: 0000 0001
VCDS-Lite
Self-Diagnosis Log
Saturday, 04 April 2020, 17:53:40:28534
Page 2
VIN Number: WVWYH63B72E334897 License Plate: X47MKX
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 3B0 927 156 AD
Component: AG5 01V 2.8l5V USA 3939
Coding: 00102
Shop #: WSC 05311
VCID: 68A354D51B6B
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
New plugs installed, engine lights with hot shot/ether
Fuses 28 and 29 good
Fuel pump relay good
New fuel pump installed...Pump runs when DC current applied directly
to pins 2 and 4
Test bulb connected to pins 2 and 4 of fuel pump harness 'LIGHTS UP'
ESS FAILS the resistance test - No resistance between Pins 2 and 3
** New ESS also fails the resistance test ** The old one is still in the car
I would like a recommendation for a known good' VW diagnostician in my area. Onsite is preferred, but will have the car
towed if I have to.
Hoping to actually use this car at some point!
TIA
Jack
You replaced the plugs but misfires may come from bad coil packs. So it seems you're on your way to replace all the coils, both O2 sensors and the MAF sensor before any other serious further actions.
Don't forget that it's a V6.
Wouldn't bad coil packs in V6 cause misfires?
Yes, but it's kinda rare. In this case, it's 3,4, 6 misfiring and random misfire. Random misfires tend to point away from coil pack issues and go towards air/fuel ratio problems..
I have a new ignition coil...I'll install it, clear the codes and try again. The plugs are new.
TX
It points to a maf reading that is out of range. It can a bad MAF, nicked/corroded wiring, or even a bad ground.
Discussion Starter #9
Thanks and blessings to all that have been helping me here.
Cleared and re-ran VCDS-Lite auto-scan...https://www.dropbox.com/pri/get/Public/02%20GLX_2.pdf?_subject_uid=63042105&w=AAD306RfSimG-A7c9B7BYJCWlFR_GlHjhLHbS5FbSQhl4Q
Status...No change...No noise from fuel pump except when DC current directly applied. New filter, plugs, coil pack...PCV hoses cracked and awaiting new.
There is an odd but cyclic clicking noise from the firewall to the right of the radio when the ignition is on. I need to get just that little bit closer.
Coding: 07251
Shop #: WSC 05311
VCID: 6AA72EDD0567
1 Fault Found:
P1118 - 35-00 - -
Readiness: 0110 1101
Coding: 00102
Shop #: WSC 05311
VCID: 68A354D51B6B
1 Fault Found:
The long list of original codes was caused by a blown fuse or a fault in the wiring.
The current codes you posted shouldn't prevent starting.
Check all fuses with a meter.
Do a full scan (all modules) and post results.
Discussion Starter #11
Definitely leaning toward a wiring fault...I'll be on a bucket reading fuses for the next few hours. My windows no longer moving...though I can hear relays in the doors clicking when I push the buttons.
IIRC there are no relays in the doors.
I suggest you ask a moderator to combine your 2 threads, it is confusing and hard to follow.
1 - 12 of 12 Posts
Status
