1 - 12 of 12 Posts
Does anyone's car do this also? I drove down the road to the gas station which is about 5 miles down the road and I pull in and was sitting in my car while it was running for about 5 minutes with it in park. When I put it back in drive and started to move, I glanced up and looked through my mirror to see a cloud of gray smoke from my exhaust :shock: :nervous: What is the matter with it :???:
You and your car smokin stoogies? :crazy:
It could be a bad gasket somewhere! Was it cold out side, sometimes when a car starts in the cold you will see white smoke out the back end for a short time, but you said grey smoke, the only thing I can think of is a gasket somewere! But that is a guess. :thumbup:
Rich :wink:
Grey? Black is bad... that's oil.. but grey? I have no idea what that is... probably oil as well...
How many miles do you have...? :roll:
Discussion Starter · #6 ·
Think when the dealer over filled the oil could be a cause? I had them redo it about a month ago though and put it to the correct level
Something similar happened to me a month ago.
A vaccuum hose got disconnected. I reattached it and started the car and I saw smoke from my exhaust.
I thought it was in rich condition, so left the ignition in ON for 3 minutes to readdapt, and didn't see smoke anymore.
Discussion Starter · #8 ·
It does not do this every time. The last time it did this was in winter and I didnt let it warm up like the manual says you are not suppose to and I just put it in reverse and pulled out. This time when i did it, it was 91 degrees outside. I have 41k on it.
is ur CEL light on?
and while at the gas station, you never turned off the car right?.....
outside temp was 91 degrees.....
41k miles.....
just MAYBE :roll: the smoke was a moving cloud that another car had puffed up, and well, when a motor is cold, it tends to puff a small amount grey(very light) smoke normally at lower rpm's.
i always let my car warm up a bit in the mornings, usually till it get to the second bar in the temp gauge. to get the fluids warmed up and let the pistons expand a little bit, no to mention to let the oil flow and fill any empty(oil free) spots there might be.
just for safety. i learned a long time ago that it was good to let ur car warm up, and never been told or heard otherwise.....hhhmmmmmm........ :crazy: ......
im no saying the manual is wrong, but personally, i wouldnt take my chances.
i work on my own cars, and NEVER had any internals fail. and i drive hard!! and i believe the warmup is one (of many) reasons why.
my .02cents
ALfredo
1 - 12 of 12 Posts
