1 - 11 of 11 Posts
I have a ghost or something in my moonroof. It will open and close at its leasure. It wil go from shut to vent, and go from open to partly closed with no command and/or warning. It is so annoying to be going down the road and the roof starts opening and closing.
Any ideas???
Thanks
Water/corrosion at the Comfort Control Module wiring? It's located in the floor under the driver's footwell. Supposedly you can pull the trim + carpet easily to gain access.
try going in and making sure all the connections are tight between the wiring harnesses from the controls to the motors, my friend's B5 was doing that as well, and we just found a loose connector. :suspicio:
Check the info forum for W8 overhead console. Removal/access instructions are in there.
1 - 11 of 11 Posts
