I have VVu available; I had another problem today, the air sensor changed and during engine operation disconnected the plug from the sensor since the traction control lamp did not go out and the gearbox started to twitch very strongly (kick) from that moment. I can’t understand why it would be
If you mean you unplugged the MAF sensor and then drove, yes it will screw up the shifting of the Auto trans. It has nothing to do with traction control as that is run off the ABS system.
Reactions: jjpark
Try turning the key on and off a few times (Don't start car) with a 30 sec pause in between each on off cycle. This should reset the MAF.
