With fly-by-wire electronic throttle there is no physical connection, so don't know what to say about that...just where you're feeling a real vibration.
Any CEL, codes ?? If you get a misfire code, switch that coil with another cylinder, to see if misfire moves there...if so, replace that coil.
If no codes:
I would still look to the ignition coils....
-Look at the rubber sleeve on each for ANY cracking, holes or separation...would short to engine head and cause misfire.
-Check all coil connections...output stage connecters.
-Make sure you didn't disturb any fuel injector connections either.
If no codes:
