1 - 13 of 13 Posts
I used to get 280 miles out of a tank around town. I'm now getting the fuel light at around 225 which gives me about 20 more miles before getting gas. I'd say that's quite a drop. In the past 6 months, I've replaced:
O2 Sensor
CTS
New Plugs
MAF
Cleaned TB
Cleaned IAT sensor
Not sure what else is left. I'm at 108,000 miles and the drop started around the time I changed the engine mounts 2 months ago.
· PassatWorld Elder
Have you scanned for any codes? Is the CEL on? Did you test for boost leaks? Has power dropped off?
No CEL. Scanned for codes with no returns. Maybe a little sluggish, but not drastic. Checked for vacuum leaks with starting fluid. Not sure about a boost leak or how to check for that. Did get a strange, light plume of smoke on start-up a few times. Also, sometimes it turns over several times before starting. I'll let off the starter and then back on again and it starts-up.
· PassatWorld Elder
There is a thread on building a boost leak tester. Usually you get a code if the leak is large enough. The turbo outlet hose and the DV are the only thing I could think would be disturbed by a motor mount change on the 1.8T.
Discussion Starter · #6 ·
I did the pressure test just now. I found a significant leak at the connection where the PCV meets the TIP. I think that's what it's called. The gear clamp had not been tightened back after I did some other work and it was just there. Air and bubbles were very prominent at this location. Could this be enough to cause me problems?
Fuel line Auto part Engine Vehicle Pipe
Discussion Starter · #8 ·
Air intake temperature sensor has now been replaced. When I filled up today, the mileage calculated until empty showed 355 miles. It used to say 425 miles until empty. I only got 240 miles from the last tank. Engine management is obviously not calculating the same as it used to.
· PassatWorld Elder
That means nothing. It only shows based on your current mileage, calculated by the fuel level. Once the MPG improves due to repairs, the numbers should rise.
Are you seeing any MPG improvement yet?
Our '02 variant 1.8t is still getting bad MPG (sub 20) since we inherited it 3 months ago. It was in rough shape mechanically, sister wanted to put it out to pasture after putting in a donor AWM motor three years ago (timing belt broke on the hwy), and then a rebuilt Tiptronic less than a year ago. 235K now on the odo. I figured it just needed a little TLC and a pretty hefty tune up.
So far:
Using only 91Octane.
New OEM NGK sparkplugs, new valve cover gasket, new coils
New air filter, new fuel filter
New Cat and both O2 sensors
New timing belt, thermostat, coolant temp sensor
New accessory belt, new a/c belt and tensioner
New pair of axles (Chinese)
Stock size Michelin Energy with 40K and inflated to spec.
No more CEL after P0420 cleared, and no more misfire codes after plugs/coils. But there is a stored code for brake booster vac pump.
Starts and runs smooth and strong. But it just gulps gas. No obvious leaks or cracks in hoses.
What's next?
Throttle body, MAF cleaning?
PCV, is there an actual valve somewhere? Take apart other PCV hoses?
What's a diverter valve?
Our '02 variant 1.8t is still getting bad MPG (sub 20) since we inherited it 3 months ago. It was in rough shape mechanically, sister wanted to put it out to pasture after putting in a donor AWM motor three years ago (timing belt broke on the hwy), and then a rebuilt Tiptronic less than a year ago. 225K now on the odo. I figured it just needed a little TLC and a pretty hefty tune up.
So far:
What's next?
1 - 13 of 13 Posts
