2001.5 B5.5 wagon, 1.8T ATW.
My daughter had the car out of state and had the fuel pump go out on her. The car was towed to a mechanic who installed a new fuel pump (ouch$$) Afterwards, the car ran fine until there was a 'bang' then a sound like an exhaust leak. She got the car home and I found that the main air intake hose had come off from the intake manifold. I re-attached the hose, tightened the clamp and cleared all the codes. Now, I'm getting a P0442 errors (evap system error) and there is a noticeable gasoline smell. The smell seems to be getting better and I'm hoping it's from spilled gas during the pump replacement. I re-seated the tank access cover inside the car and that seemed to help the smell.
I know I need to check all the evap lines, etc to try to track down the P0442 errors but is it possible that the 'bang' was caused by some gas vapors getting into the intake somehow? Any ideas on what evap components might have gotten damaged during the pump replacement? I'm hoping the P0442 fix is as simple as the non-attached hose fix but I'm concerned about missing something or that I'm getting excessive un-burned vapors into the intake.
