1 - 10 of 10 Posts
You just need to trim the lower section of the bumper in line with the exhaust. I painted mine with bbq black spray paint and mounted it with stainless steel nuts and bolts. I also had to cut the tips and welded them on. Fairly easy. Hope info helps. Thanks!
Another pic:
http://members.aol.com/capture1/fall2.jpg
So are the tips you're selling cut already?
Can these be used without welding?
I think Purplezr2 is considering taking them...he just bought the blend. No the tips are not cut. The're the factory OEM stainless tips for the B5.5. They place themselves just below the bumper and mount with standard U bolt clamps over the end of your exhaust. If you use them with the zender blend then you would need to cut and weld like I did in my photos shown. The pic of the tips alone are the actual ones. Sell new for around $100. Thanks!
needs more cowbell
just in case, i'd like to be in line.
PM me if b5v6 has a change of heart.
1 - 10 of 10 Posts
