1 - 9 of 9 Posts
FS: Smoked turn signals, OEM base bars,Bentley CD,Monster MatsBlitzsafe Aux adapter
I have a few things for sale from my B6 Passat that I recently traded in. All prices are negotiable. Contact me with ZIP code for shipping quote.
1. SOLD Valeo wiper blades (OEM brand, front only) Brand new, in packaging: $15
2. SOLD Blitzsafe Aux adapter. Plugs into the CD changer cord in the glovebox. I will also throw in the cord to hook up a phone or anything with a headphone jack. The plug on the unit is a little cracked, but it does not affect the function at all. $40
3. SOLD Smoked front turn signals for front bumper: $20
4. SOLD Bentley repair manual CD: $50
5. OEM Base Bars Roof Rack for sedan. They show some wear and the plastic is slightly cracked on one, but it snaps into place and fits securely. $100
6. SOLD OEM Monster Mats. Used, will clean them as good as I can. Pic to come. $40
The Blitz adapter... does it work with the MKV/B6 platform by chance?
I've been seeking an OE like solution to adding an AUX cable to my mom's 2005.5 Jetta, but it's only a Premium 7 radio, and I'm not about to change the CAN gateway module and a bunch of other isht to get an expensive touch screen radio with AUX in cababilities... If I'm reading the small text on that box correctly though, it suggests it doesn't work on it? Maybe I'm under the wrong impression that the MKV and B6 platform are some what the same? I'm just trying to use context clues here since you have B6 parts listed.
Yes, I forgot to mention these parts are all from my B6.
This thing should work in the Jetta, my Passat also had the Premium 7 radio. If you have a CD changer connection somewhere, it should plug straight into that. If you have an iPod dock in the armrest, see this (from Enfig website):
-Not compatible with touch screen radios
-Does not disable the CD player or CD changer in the radio
-Connects in the center counsel under the elbow rest where the factory installed iPod dock normally connects
-Disables and replaces the factory installed iPod dock in the center console under the elbow rest
-This car normally only has the center cosole connection if there is already an existing iPod dock in the center counsole
-Will retain the factory satellite radio as long as the Volswagen iPod dock you are removing is factory installed. So if your current iPod dock retains the satellite this unit will also retain the factory satellite radio.
In doing some further research, it looks like I'll need the one that plugs directly to the back of the headunit (the interface box.) Only because, from doing some searching around, it looks like the only place that the New Jetta was capable of installing a cd changer was in the center console under the armrest VS back in the boot, or in the glovebox. Her car doesn't even have the slot for that changer, so I doubt the plug is present.
I'll do some digging when she gets home from work...
1 - 9 of 9 Posts
