FS:
Metalnerd Drain bit tool for VWAG transmissions and gear cases. This is a two-sided tool that has a 17mm hex driver on one side, and a 16mm triple-square bit on the other.
Here is a link to view it:
http://shop.metalnerd.com/index.cgi?code=3&cat=8
From Metalnerd:
"Part MN2567 - Gear Box Drain Bit
This unusual tool is necessary for changing gear oil on many VW®, Audi® and Porsche® transmissions, differentials and all wheel drive components. Hex-end (17 mm) fits older models while star-shaped end fits later models. The star end is called out as tool #2567 and #3357 in repair manuals. Compact design will fit into your 19 mm or 3/4" box wrench or socket for maximum leverage. Heat treated alloy steel - Metalnerd Brand
CAUTION: Some late model automatic transmissions do not have dipsticks and if you drain the fluid out, you will need a diagnostics computer when refilling to tell you when the tranny is "full"."
Used once, so it's in perfect shape.
$15 + shipping.
Bonus for local pickup only: Free 0.5l of OEM VWAG 75W-90 GL-4 synthetic gearbox oil for Passat and Audi...this was leftover after a recent fill, it's the "good stuff" at about $32/liter at the dealer.
PM, email swramsey73[NOSPAM]@msn.com (don't type the [NOSPAM]) or call 508-212-6049 if interested.
-Scott
I'm checking on shipping for Dutch, I will post if it is sold or still available after that.
