Status
Not open for further replies.
ECS Tuning's ultra lightweight 14x1.5 VW oil pan drain plug with VERY powerful magnet + 12 new OEM copper seal washers. Over time, heavier metal shavings & particals settel to the oil pan and collect in the internal valleys of the pan, where they have a hard time being pumped up to the filter to be captured. If you have allways used the stock non-magnetic drain plug, you will be shocked during an oil change to see the marble size ball of metal particals on the end of this ECS plug, after a few oil change cycles the ball gets smaller and smaller untill only a light coating of metal, (which is normal). Your motor will thank you and last longer. $10.00 Shipped in the US
Status
