1 - 11 of 11 Posts
what additional is needed for the install into a 99 1.8t?
If you could source out new hardware from the dealer, go ahead, but they may not have all the parts available at that time you visit. I would recommend the ecstuning K04/K03 install kit.
Comes with the following components:
# Studs for rear of turbo that cat bolts on to (3). Oil Line gasket on bottom of turbo
# Gasket between manifold & turbo
# Gasket between turbo & cat
# All necessary copper seals (6)
# Turbo mounting bolts (3)
Here's a little take of the K04 taken for the ecstuning website:
The KKK KO4 is a straight bolt on turbo that can be used for multiple different reasons.
# Flows more volume than the standard KO3
# Can sustain high boost pressures than the KO3
# Great replacement turbo if your KO3 has gone bad
# Can be used without any special programming, although specific KO4 programming is recommended to extract all potential power from the KO4
-Lawrence :)
ralf sells for 695 new... to make it worth our while, would you do it for 620 shipped? if not, understandable... i'm sure u'll find a buyer.
island T... let me ask my local tuner if they have software for this. if so, my tax refund comes in less than a week =P
until then, put me down 1st in line =)
1 - 11 of 11 Posts
