1 - 17 of 17 Posts
SOLD: Blaupunkt San Francisco CD 70 (Skyline Series)
* 45 Watts (Max.) x 4-Ch
* 4-Ch Low Impedance Preamp Output @ 5V w/Sub Output
* DSA Digital Sound Adjustment / Automatic Self Adjusting EQ
* DNC Dynamic Noise Covering / Combats Long Duration Ambient Noise
* Calibrated Microphone Included
* Internal Pink Noise Generator for Sound Measurements
* User Adjustable 7-Band Digital EQ with 3 Memory Banks
* Selectable EQ Presets for Different Music Types
* DigiCeiver Codem D All-Digital Tuner including RDS & Sharx™ Adaptive IF Switching
* Improved Multicolor Dot Matrix Display with Animation & 2-Tone Faceplate
* Selectable European & USA Tuning Modes
* 24 FM / 12 AM Presets Including 6 FM / 6 AM Travel Store Presets
* 2-Tone DIN Flip Panel Faceplate with Stealth Type KeyCard Holder
* Softkey Design Controls Improve Ease of Use
* RDS Radio Data System with Station Call Letter Display
* Station Naming, Radio Text & Preset List
* Digitally Processed AM Interference Suppression
* 12/24 Hour Clock
* Blaupunkt's Exclusive BP-1 CD Deck with 3-Beam Holographic Laser Pickup & 1-Bit/32X Oversampling Digital Filter
* DMS plus CD Naming, CD List, Scan, Mix, Repeat, Peak Level Meters & Last Position Memory
* Menu Options including: 6-loudness Levels, Adj. Scan Scan Time, 3 Hi-Cut Levels,
Loc/ DX Level Selection, STM, Clock, & Aux-In for MP3 / MD / DVD
* High-Pass and Low-Pass with Selectable Slopes
* Selectable Outboard Amplifier Turn-On Delay
* Subwoofer Output with selectable freq @ 80/100 Hz
* Includes Handheld RC 10H Infrared Remote - Thummer III or RC09 (both optional)
* Defeatable Internal Amplifier
* Controls Optional CDC A08 & IDC A09 CD Changers
SOLD
Click Image for Tech Specs.
Discussion Starter #2
My PM is not working here right now for technical reasons. Please contact me in the thread or via email: robpaller(at)gmail.com
does it come with an adapter? ... if not, how hard is it to rewire?
I might be interested :)
btw... is it the same dimensions as the stock? and why are you selling? :)
I have fitted this radio in both a 99 Passat B5 with a single DIN OEM radio and a MKIV 2004 Jetta with a double DIN radio. I have harnesses for both and the antenna adapter for the single DIN setup. The antenna adapter I bought to go with the double DIN radio did not appear to match up. If you have a double DIN radio you will need to obtain something (pocket or gauges and panel) to fill the gap.
I am selling it as I decided not to put in three aftermarket gauges and pull my Monsoon radio out of my GLI to mount the gauges.
I am interested...though am still researching other radios.
Is it plug and play into a 99 B5? Do you need any harnesses and will that be included? How much for shipping?
Does it play CD-R/ and CD/RWs?
And would you accept paypal?
Thanks!
Discussion Starter #11 (Edited)
I will include the harness and antenna adapter that I used with my 99 B5 (non-monsoon).
It will have the hand wireless remote, IR eye (wired) for the remote and the microphone (wired) for the DSA feature. Plus I think there is a CD in the radio right now that I forgot to take out. You can keep or discard it. :D
I haven't tried CD-RWs, but I have used CD-R media in the radio with no problems. However, it will not read MP3 file formats. It must be an Audio CD format.
Yes, I would accept and prefer Paypal.
Discussion Starter #12
Postage to 20901 for a 5lb (estimated) package via USPS Priority Mail is $8.00.
Do you have a preferred shipping company?
Haha..you're good! Car Salesman?? hehe.
Just did more research on this radio..and had a couple more questions.
Do you have both Key Cards? Any scratches etc on the faceplate? or otherwise any problems with it? Got any pictures of the actual radio?
Also was going to offer $150 including shipping...
Let me know.
Discussion Starter #14
Let me know.
Yes it has both key cards.
Any scratches would be light from general use for about a year in my B5.
No problems with it. I had it wired up to my GLI a couple weeks ago but decided to go a different direction with my audio system. (Leave the OEM deck and considering a PhatNoise MP3 jukebox).
I will be taking pictures of the actual radio tonight, hopefully. I will post them up when I am do.
No, I am not a car salesman or in sales for that matter. :)
Ok sounds good. Will wait for the pictures and make decision tonight...thanks!
Oh and one more question..installation...will it fit the b5 perfectly or are any mods required..(I also have a 99 B5).
Discussion Starter #16
There is a metal bracket that comes with the radio. After you pull the OEM radio put this bracket in the opening. Press several of the tabs on each side againts the opening in the console to "lock" it in place. Then once you have the wiring figured out slide the radio in and your should be golden. :D
1 - 17 of 17 Posts
