TENTATIVELY SOLDB5 headlight leveling parts: $175 shipped w/i the 48.
Pretty much everything you need to equip your B5 Hellas Projos/Hella look alikes. All you'll need in addition is the 18g wire to make the rest of the wiring harness, electrical tape and some scotch-lock connectors.
(1) 3B0 941 333 C - Rheostat for headlight range adjustment
(1) 3B0 941 295 - Adjustment motor for headlight
(1) 3B0 941 295 B - Adjustment motor for headlight
(2) 443 941 323 - O-ring/Washer for adjustment motors
(6) 357 972 741 - Grommet, single Wiring Seal, 3 for each harness
(2) 357 972 753 - Housing for headlight Adjustment 3 pin
(1) 1J0 972 723 - Harness for dimmer switch
(6) 000 979 225 - Wire repair for all harness plugs
Reflex silver (LA7W) paint touch up kit: $15 shipped w/i the 48.
Bought used from Aowhaus a long time back, I found out I have Satin silver and not Reflex, so I've never actually used it. Includes syringes, la7w paint, clear, rubber squeegee, clear blender-stuff, 2 rags and instructions.
OEM full size mirrors SOLD
pair of NA B5 sedan tails SOLD
AEB intake manifold $60 shipped, $90 shipped for casting lines smoothed and manifold sanded to 220 grit for Powdercoating.
Large port manifold, can be used on later engine codes with 034's phenolic spacer. The throttle body hanger can also be hacked off to look more like small port manifolds.
Thanks,
Andrew
Thanks,
Andrew
