1 - 20 of 48 Posts
That would look so pimp on a B5! Do you happen to know if there are any HP gains from a front mount mod? GL with the sale.
You don't gain horsepower from an intercooler. It keeps you from losing if from heat. There use to be a thread about it, but I can't find it off the top of my head.
I'm running the same unit on my car and it works great.
do you have the box it came in with all the paper work? If so whats the part number on it?
i know i've mentioned this in a few threads already but i used to believe that the fmic gives no add'l gains but i just recently installed mine, and maybe depends on the setup but i gained 1-2lbs of boost, which in turn made the car more aggressive. i know there's a certain point where add'l boost doesn't yield more power, just runs the turbo hotter but i guess with my conservative chip, the extra boost helped.
Hey when did you get this done? Who did the work? I got off the FMIC bandwagon because paying 700 plus for no HP and no gains seems foolish. I have a 1.8T that is chipped with GIAC, has an exhaust and its slow to me. Could you explain your newfound exgressiveness? Also how much for everything? Can PM or post here
Discussion Starter · #18 ·
Well most people think there is no gain of HP when getting a FMIC but it all depends on the setup. If you have a stock setup you wont gain nothing at all. But if you have a bigger setup or better tuning it would help a little. I think GIAC offer a conservation program.
1 - 20 of 48 Posts
