1 - 9 of 9 Posts
Could someone please send me a picture of how the connection links are installed? Does the swaybar go on the inside of the ‘fat’ end of the control link? (Oh, sorry... big boned)
see pic - is that setup ok? Notice the, ahem, rotund part at the bottom, separating the sway bar from the control link... and does it matter which way the bolts go?? I have both bolts on the outside wheel side of the connection...
100321
Is this correct?
Is this correct?
I believe yes. That extension is to compensate the gap with the upper part.
Thanks. All tightened up now and it looks better.
You tightened everything up with car on its own weight?
That’s not good? Do I need to put both wheels up on blocks to do it right?
I hand tight those bolts, drive up on ramps and tighten them getting under the car.
I do the same with the control arms.
Discussion Starter #8
I didn’t have ramps. The wheels were on the ground and my laziness paid off as I squz (past tense of squeeze in the east coast of Canada) under and tightened them.
Reactions: axenstar
You should be good with the wheels on the ground. I don't think I could even get to them like that, but my car is a bit lower than stock.
1 - 9 of 9 Posts
