Then adjustable would definately be the way to go.....S_Klass said:aprpassat already has the rear sway, he's thinking of adding on the front sway to finish up the package.
I do! They springs that have a stiffer rating then HR or Eibach are Vogtland springs! I was talking to a guy yesterday inquiring about them, and he siad they are even stiffer then my Neuspeed which I like but am taking out due to not lowering the car enough all they way around! I hate how there is more gap in the back then in the front!aprpassat said:Ive already got the shocks adjustable bilstien sports and rear 28mm sway bar. I have HR OE springs. Does anyone know which springs have a stiffer rating the HR sports or Eibach Prokit?
I believe your refuring to my post! I dont know if he has tested them! He just said they are a little stiffer then the Neuspeed!Macabre said:Yea, but does he know how stiff all those other springs are, or is he talking out of his ass? None of those companies publish their rates so unless he bought a set of each to measure..
i was VERY skeptical due to the overwelming posts by fellow CB5ers and held off on a front and craved the rear....but i got the oportunity to use a front w/o a rear and must say...in comparison from no sways to only a front (which in this case isn't to valid since he has a rear already) i REALLY enjoyed the front bar and liked how it flattened out my front end. I used it in conjunction with a C-bar and Sparco Strut tower bar...so my front is pretty stiff and driving it is a pure joy. My only limitation now are my front tires that scream in a turn and freak me out every time....once i get my 18s back up front i'll be likley to enjoy the setup even more.D.Passat00 said:it really depends on what you like. i know a fellow CB5er who has a front sway w/o the rear sway, and likes it that way.
If those Vogtland springs are a little stiffer then mine, then you should be fine, I am only running springs right now with stock shocks! When I get my Vogtland springs and koni shocks it will stiffer but still should be comfortable!!aprpassat said:Rich,
That pic of the white passat does look good. Maybe the Vogtland springs would be another to consider. How well is the ride with those springs?
