Hi all. I have 98 B5. About a year ago the noise from front suspention started to bother me.
This is not only clunk noise when you break, but also pretty loud noise when you go over big bumps (feels like you need some force to be applied to get this sound of something being very loose on both sides). Although if you are going over the bumps while holding the brake, the noise isn't as big and sometimes disapears....I gues this depends on your speed.
I have always been a patient reader here, so this is what I did:
1) The front wheels were checked and top control arms replaced. Some noise gone.
2) Tie rods replaced on recall.
3) Engine mounts were replaced (right and left).
4) I replaced all the subframe bolts #27, 28, and 31. most of noise was gone, but some came back again in 2 days.
5) I replaced the sway bar links from ECS. Didn't help very much. Right after this the axle noise came on low speed especially.
I would like to hear your coments before I replace all the parts on my car.
I also noticed that the front engine mount bushing is cracked. Could this be the problem for the noise?
I'm also preparing myself for the transmission (manual 5spd) mount replacement. What are the symptoms of tranny mounts to fail? Any pics of bad ones?
The axle noise makes me think that the sway bar links either weren't designed correctly, or something needs to be raised/lowered/adjusted (maybe tranny mounts?) for the axle to be in the correct position to the engine. It seemed that the links were shorter than the original ones, so I had to loosen all the bolts on the sway bar in order to connect it to the control arm, then tighten everything up. Makes me think that the front assembly moved a little closer to the sway bar. The noise sounds like the ballbarings were shot (louder when you turn). But this doesn't happen out of the sudden on both sides, especially with no CV boots ripped... :???:
Your suggestions please. :thumbup:
