Just in case anyone has a similar issue, I figured out the problem. There are 2 sensors inside the car for climate unit. The one that I had that was defective was the G89 or fresh air inlet temp sensor. Part # is 4A0820539A. It is located way up high behind glove box. It throws code 313 when defective. It can be seen under pollen filter.
The one I had first removed was the evaporative sensor. It is part # 1J0907543A. It is located near bottom of ac blower unit. I did not realize this was different from air inlet temp sensor. The way I found out was when I disconnected it, I got a new code 332.
Hope this helps.
Hope this helps.
