1 - 7 of 7 Posts
As part of my '99 "restoration project" after pulling the carpet (the block and heads are at the shop getting zero-timed. Thanks KSEADUB and AndreasPassat for the inspiration, I'm now going deeper into the rabbit hole!) I found this while cleaning. This view is of the passenger side floor inboard of the front seat rail looking back to front. The hole is where a plug goes, it was there, just loose. But what is all the tar-like stuff? That's the only area on the entire floor that has it. It didn't come through the carpet, no evidence of that. Comes off easy with a plastic scraper but what the heck is it?
[URL=http://s1262.photobucket.com/user/p1muserfan/media/Passat/2016-12/20161201_170718_zpsxflqul3b.jpg.html][/URL]
Yep...same goes for under the rear seat bench. And unless you go back with something like Dynamat or other weighty soundproof material, the road noise (post-project completion) will make your ears say Hyundai or Mazda.
Discussion Starter · #5 · (Edited)
That's the weird part, the VW version of Dynamat is everywhere in the car. I find it hard to believe that all of the tar-like sound proofing "washed away". I can't find evidence of water intrusion anywhere. No water stains, corrosion, nothing. Module boxes and contents are pristine.
[URL=http://s1262.photobucket.com/user/p1muserfan/media/Passat/2016-12/20161202_155643_zpswcigocjv.jpg.html][/URL]
[URL=http://s1262.photobucket.com/user/p1muserfan/media/Passat/2016-12/20161202_155655_zpss1zl1f2k.jpg.html][/URL]
Probably a mixture of the sound proofing, Juke pad (The thick padding that is on the backside of the carpet) along with years of dirt. At one time someone may have spilled a lot of soda. Cleaned the carpet but never pulled it to clean under it.
1 - 7 of 7 Posts
