1 - 7 of 7 Posts
Hey guys,
Just recieved my Forge DV in the mail today.. It came with 3 springs Green, Yellow and Blue and 2 spacers. The green spring is preinstalled in the unit. Is the green spring the right one for my 02 1.8t with APR 93 program? I believe the green is the weakest spring then yellow and blue is the strongest.. :confused:
Mine came with the green in it, i put the yellow and could not be happier. But unfortunately i am not chipped yet, but i will not have to switch it when i chip due to the yellow being good for 5-15 psi.
Forge says yellow is good for 15-23
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
yea yellow is for 15-23 psi, i am not sure if its good for your car running such a strong spring with 7-8psi of stock boost.
Discussion Starter · #6 ·
Well, my car is APR 93 octane chipped.. So I guess the yellow is the correct one?:confused: Or is it safer to use the green spring?:nervous:
You should be fine with the yellow. I only advise trying the Green on a chipped car if the owner can log actual boost versus desired boost to verify that it isn't leaking.
1 - 7 of 7 Posts
