Hi,
I have a 2000 reg Passat B5 with Climatronic.
I have foam coming out of the interior vents occasionally, and I believe it's caused by the foam disintegrating on the blend door. My aircon doesn't seem to work very well and I so this coupled with the foam leaves me to think its the blend door.
Earlier on today I thought I would start removing parts to see where the blend door is, whilst I wait to buy the replacement foam. So using the guides I could find, I removed the drivers side lower dash, glovebox, radio, Climatronic, centre console. However, I couldn't work out how to remove the passenger side dash (without the top dash - which I was reluctant to remove as to me it looks like there is a way to remove the passenger side dash without it?).
Anyway, after all this I couldn't see the blend door anywhere, so my question is where is the blend door on a Passat B5 with Climatronic? And what can I test to verify it is in fact the blend door? Any further hints or tips please?
Thanks,
James
It will be coming from all the flaps etc.
You will need to remove the complete dash to remove and repair the Climatronic unit.
To expand on that:
You'll need to remove the complete dash, and remove and disassemble the HVAC box, to repair the blend flap.
It's a problem that goes back to the A1 chassis days, unfortunately.....
Thanks for the replies. That sucks because I don't think removing the full dash is a job I could do confidently, and it would require discharging and recharging the AC from what I have seen?
I'm assuming there is no way to repair the blend door without discharging the AC either? It's a shame because I saw guides for other models whereby you could remove the lower dash and radio etc and repair the blend door albeit in a very tight working space. I was hoping the B5 Passat was the same.
If you remove the cabin air filter, you should be able to view the door from above. I am not sure if you can manually move the door without stripping the plastic gear that moves it.
