1 - 3 of 3 Posts
I just bought a pre-owned 2013 Passat SE 2.5. I have my phone connected to Bluetooth. The problem I'm having is that when I try to listen to the radio (FM or SAT) it keeps switching back to BT-Audio all by itself and I have to keep pressing the FM or SAT button. Sometimes it happens by itself. Other times it happens when I press the home button on my iPhone or when I plug the charger into my phone. Please help!
Chad, check out the B7 forum and post there if you can't find anything.
Flavan, same to you after you post a second time here and the forum lets you post elsewhere. While an occasional member may answer a question in the noob tube, this isn't the place for it and many will go unanswered, leading to frustration.
That said. Look into firmware updates for your radios. I know they have them for the RNS units. I had a '15 Passat TDI SEL Premium.
This site below has a lot to look through for a possible fix.
https://www.my-gti.com/category/in-car-entertainment
1 - 3 of 3 Posts
