I've been lurking around the forums for a while and would like to thank all those you post the "how-to" topics. They are invaluable.
Anyway, I've had an FK kit on order since the begining of April. I recieved it about two weeks ago and finally got it installed this weekend. I'm a little concerned over which kit I actually received. I orderd the 35/40 kit, but the boxed was hand labeled as a 45/55 kit and then crossed out and labeled as the 35/40. The drop was around 2" - 2.25' all around. It's pretty low. I rides nice and comfortable, just dropped a bit more than I expected.
I've done several suspension isntallations on different cars... this one was the most challenging. I was unable to remove the upper contol arms as the bolt connecting to the steering knuckle was frozen. So I unbolted the control arm assemble and pulled it down enough to get to the strut bolts. Then rebolt the control arm assemble to the body to allow for clearance of the lower shock mount.
Then the issue of clearing the lower shock mount over the lower control arm. PITA!! I had to compress the spring and jack down the suspension to get it to clear. Rear went ok, minus a bolt breaking on one of the upper shock mounts.
Anyway here is the first snap shot... obviously a before and after.
