1 - 3 of 3 Posts
Just got my AEs from the GB and installed them. They work fine with the stock switch (also bought the Euroswitch but haven't installed it yet as it's the one with only 1 logo and not the 4). Only problem is the passenger side is point up and to the right a bit (left one seems to be pointed fine). I tried the 2 adjustment screws as noted by the Haynes manual but it didn't really seem to move much. I noticed on the back of the AEs 2 adjustment screws but didn't touch them can someone tell me if those level the lights and which one does what (horizontal, vertical)? Pics would be helpful. I have used the search but nothing significant (I used search to install them with the stock wires and did the fog light wire switch). TIA :banghead:
The adjustment screws on top are what you need to use. If they are like the stock headlights you have to turn them a long way before you see significant movement.
1 - 3 of 3 Posts
