Sorry it took so long, but here are my graphs....
1st dyno with K03 with APR 93oct program (18lbs)
181.58whp
207.57wtq
GT28R set at high boost (19lbs)
248.65whp
268.5wtq
GT28R set at low boost (151bs)
231.88whp
228.43wtq
What'ya think? Again, this is from a GT28R, 415cc injectors, AFPR set at 3.75bar, 3" delete pipe and 2.5" TT exhaust, true CAI, 3" MAF housing, STOCK COILS (soon to be replaced with BERU's from 034Motorsport), stage 3 6puck clutch with lightened flywheel.
The program from Unitronic will allow for 20-21lb solid, spiking at 23, but installed the Boostvalve Dual Stage MBC to hold at 20 only. When I do rods, then I'll push it to the max 23-24lbs!!!
Suggestions and feedback is always warmly received...
Much luv
Juce
Inverted colors....
is this setup a gt28r or 28rs?
Only a 28R with internal wastegate, 15lbs low boost, 19lbs high.
Gonna use is to break in the 2.0 build, then once I feel everything is good to go, 3076R will go in!!!
