Digital said:
Let me think this out, and decie how much i want to spend and how much time i have to spend on this project. Ill let you guys know right now that i was planning on removing half th turbo (the part that powers it and connects to the headers) and replace it with a electronic motor. . . IM not looking for SC preformance just an extra 15-25 hp. . . . my goal is to get my car to run 230-240 hp (any more then that on a FWD car is not a good idea, to much torque steer) . . . . .
So let me get this right, your after just the compressor part of the turbo and to use it like a supercharger and power it with an electric motor.
So the problems i see are :
1. Finding an electric motor compact enough and strong enough to spin the compressor wheel to a high enough speed to create any reasonable boost.
2. Upgrading the electric system to cope with the power drain from the electric motor.
3. Getting someone to design and build a speed controller for your electric motor, that works with your ecu/engine speed to bring in the boost.
4. Upgrading the injection system/inlet system, pressure sensors, airflow meters.
5. Getting someone to be able to re-program your ecu.
6. Upgrading the exhaust system to reduce the backpressure.
Man there are a lot of things to think about and alot of things that would need to be one off designs made for your car and not just off the shelf.
I think the cost would far outweigh the gains on this project.
For the small gain in power your after, i would imagine you could add some standard upgrades to get close to that if not more, like :
Custom ecu reprogramming (i think a generic chip change gives you 12hp gain, so a custom rolling road/dyno program that works with the other mods i have suggested would reach your power goal, if not exceed it)
Induction Kit (+3-10hp depending on cost and design)
Freeflow exhaust system (+3-10hp depending on cost and design)
Ported and matched manifolds/heads/throttle bodies (+10-?)
Cam change
And the above is stuff you would have to do if you went your compressor route anyway and should be available off the shelf so to speak and be a whole heap easier and cheaper to do.
Your best bet would be to get in contact with some people that race the v6 or companies that build & tune the v6 engine and get their views.
