How many? Just one?This is a feeler only to see if there would be any interest in a B5/.5 Front Upper Stress Bar/Brace. Price would be around $150. Would be made from Aircraft aluminum and using Audi Factory endlink brackets,
No drilling required, just bolt on.
Can I ask what grade Aluminum you will be using? There really isn't such a thing as "Aircraft aluminum". It's more commonly used in marketing schemes to make you think your getting good stuff. Aircraft use all different types of aluminum, but for structure mostly 7075 grade is used.This is a feeler only to see if there would be any interest in a B5/.5 Front Upper Stress Bar/Brace. Price would be around $150. Would be made from Aircraft aluminum and using Audi Factory endlink brackets,
Pending additional info requested above, I'd also be interested...Can I ask what grade Aluminum you will be using? There really isn't such a thing as "Aircraft aluminum". It's more commonly used in marketing schemes to make you think your getting good stuff. Aircraft use all different types of aluminum, but for structure mostly 7075 grade is used.
I would probably go with 6061-T6, It has been used prior and works great. I wasn't specific in materials yet as this is just a feeler.Can I ask what grade Aluminum you will be using? There really isn't such a thing as "Aircraft aluminum". It's more commonly used in marketing schemes to make you think your getting good stuff. Aircraft use all different types of aluminum, but for structure mostly 7075 grade is used.
