Having failed the UK MOT on emissions 2.5% CO I finally manged to get the codes read.The garage that did the test recommended a new Cat.
The codes are 17916 Idle sys.learned value upper limit attained,16518 o2 sensor No activity detected,16519 o2 sensor circ,sensor 1 malfunction.
As I had change the sensor last year I thought this couldn't be the problem.However I had changed the can cover gasket recently and used RTV gasket sealer on it and recently marginally overfilled the engine oil level.
Can either of these have killed the o2 sensor? Is the first fault code showning that the upper value limit attained showing the the fuelling is too rich ,I have no idea what the fist code means
Any help would be much appreciated
