1 - 8 of 8 Posts
So I got to VAG my B5 for the first time last night (with my own setup). We have been having intermittent CELS (emissions workshop) since we got the car. Every time I have had it VAGed it tells me I have an emissions system problem. I was suspicious that it was an exhaust leak. Not so. It's not a big deal as I suspected but it's not an exhaust leak.
So it turns out that I need to change the EVAP purge valve. I would like to buy the part and do it myself and then do a writeup on it when completed.
If anyone has done this previously might they give me some advice? Are there any complications, tricks or other issues to be aware of? I know roughly where the cannister is but a picture would also be of help. I do not have a Bentley manual.
I'm going to do this work on a 2000 V6 variant, manual e.c. ATQ. TIA for any advice! :thumbup:
My VAGtool also was registering a rough idle and a misfire (cyl4 & 6). It is idling roughly but the misfire ends once idle has settled. Can anyone tell me what may be wrong? I plan on doing a full timing belt job in a month or so.
6th Grade
The valve is right there to the rear of the airbox.
One hose going in, same size hose going out, with a two pin electrical connector in the middle.
You'll need a couple of new hose clamps-one for each hose.
The valve is probably stuck open by your description. You'll need to replace the valve before you can truly diagnose the misfire issue.
I have the same intermittent CEL. I found the valve, removed the pipes going to it, examined it and didn't find it to be stuck open. I then knocked it around to see if any carbon would come lose. Not much did.
I stuck it back on and turned the car on and listened for the rapid clicking noise that indicates a working valve, about 15 seconds after the car had been started, it started to click as usual.
A couple of car starts later the CEL cleared itself.
So before you go replacing your valve, make sure you hear no clicking with the engine on.
Regards
So did you replace it? I got the CEL back on when I was sitting in stop-n-go traffic in Boston. So gonna replace the sucker if you did and got good results. If you did replace it, how much did it cost?
Regards
Mine's been doing this for over a year or so. Happens every two to four weeks, usually after a long run in commuting to work. I clear the code and keep on going. Dealer didn't seem to know which version valve was needed and quoted prices of $60-80. I like the idea of trying to clean it. Maybe soaking it in some solvent or trying WD-40. Anyone have success?
1 - 8 of 8 Posts
