1 - 9 of 9 Posts
03 Passat B5.5 1.8t 46k miles
Just diagnosed what started out as a ticking noise and has developed into a squawling noise at low rpms to be a shot fan clutch bearing.
From an afternoon's googling on PW, Audiworld and everywhere else in-between I've learned that to remove the bearing is a PIA and that the part is expensive toboot. I've managed to track down an EFK at http://www.vastperformance.com/ which seems fairly economical but I have several questions first.
- how much of the front clip would I have to remove if I were to replace the shot bearing with an oem part?
- how much of the front clip would I have to remove if I simply did an EFK and found a shorter belt to negate the pulley?
-if I've got to remove the front clip - should I do the timing belt or wait another 15-20k?
-any other vendors out there for an EFK?
-if the efk is not a good option - where can I get the fan clutch bearing besides the stealer?
Thanks in advance - Rex
I'm pretty sure it's not the viscous coupling - there's quite a bit of play in the fan/bearing. Any vendors for the bearing itself?
Thanks for the info tho.
My fan was sounding like a spitfire taking off. Think the viscous clutch went initially and then the bearing after continuing to drive on it. I could wiggle tha fan by a centimetre or so. got a new fan clutch unit for 50 or 60 quid a swapped it in. Fine now
Founder of the STFA
I don't think these go too often. Might be worth checking car-part.com for a used part.
Discussion Starter · #7 ·
Your greatest contribution - finding a source for a complete EFK.
People will adore you.
Well I called Evo and they do still stock a kit for $150 but it's not on their website. From what David was saying it's the fan, brackets and wiring to do it - does not contain a serpentine belt or any of that good stuff.
I'd reccomend the EFK and timing belt at the same time. As the motor will need to go into the service position to accomplish both jobs.
I tied my efk into the a/c fan as it is thermostat controlled and turns on automatically as well as manually with the A/C switch.
Hope this helps,
Cheers,
Malcolm
1 - 9 of 9 Posts
