1 - 20 of 32 Posts
Well, this past week I went to get my car inspected. It failed (as the title of this thread indicates).
Font Number Rectangle Circle Document
My CEL came on last Sept. and I've cleared it a couple times. I cleared the CEL before I went for the car inspection and BAM. Failed even though no CEL. Drove it around for a few days and it's on again.
This is what I'm seeing:
Font Technology Electronic device Screenshot Display device
And
Product Rectangle Font Parallel Pattern
I'm really hoping it's a simple fix as I hear the SAIP running at startup. Is there a DIY on how to check/replace the SAIP hoses?
· PassatWorld Elder
You can run the SAIP with VCDS to see what sections of the system work. It will attempt to run the pump and open the solenoid. Narrow it down from there.
if the pump is running well it's probably either the piping from the pump to the combi valves, the combi valves or the vacuum that actuates the combi valves. Since you are getting faults on both sides I'd guess the combi valves are OK and either the plastic tubing from the pump is broken or you don't have enough vacuum to activate the combi valves.
You can check the combi valves with a vacuum pump or measure the vacuum with a gauge but the first thing to do is just physically check the condition of the plastic pipes from the pump and as mentioned above, the vacuum lines. Also check any relevant vacuum check valves that might be in that circuit too (if any, I don't have V6).
Discussion Starter · #6 ·
Yeah, I searched last night and saw a thread saying that
Could be the pump, but check vacuum first. The thin plastic tubing going to the combi valves gets brittle with age, and is a cheap replacement.
Yeah, found a couple threads saying the vacuum hose could be the culprit.. Found this thread but I'm not clear as the words are great but the pictures don't have any color coding.. Going to keep searching.
Discussion Starter · #7 ·
Found this video from "The HumbleMechanic" about using the VCDS:
But I'm not see a selection to run the SAIP and test the system in the "Output Test". I'll have to look at the video again...
Discussion Starter · #8 ·
I'm going to have to sit down and research what you're suggesting..... Thanks!
He’s saying to get a flashlight and hunch over the back side of the engine. First look intently at all the vacuum hoses and lines to see if they’re intact. Personally I would just buy some vacuum hose and the thin hard tubing and replace it all while I’m there. If needed, you can use a Mityvac (handheld sucky thing with gage) to apply vacuum to see if it holds or you have a leak.
Also he is saying check the plastic discharge hose from the SAIP pump, which is nestled up front behind the bumper cover. That hose snakes its way up and back to the combi valves and also becomes brittle with age.
Discussion Starter · #10 ·
I looked online and here to try and find a DIY video or something with pics specifically identifying the vacuum lines. Not too successful so far. What I've found so far is:
So far I think this is one of the pieces that should be replaced?
Also found this thread:
In reading the thread, I'll be needing a 6mm hose and a 3mm hose too?
I went to the EKTA section of this site and went through the engine, clutch pdf and can't seem to find the hoses and parts. I looked at 78 of 116 as it's for the V6 but I'm not seeing the T or the vacuum hoses. Perhaps I'm looking at the wrong pages?
· PassatWorld Elder
Here is the solenoid and vacuum line for the Combi valves (far left), which connect to the SAIP.
Motor vehicle Hood Light Automotive tire Automotive design
This is the connection to the plastic tube that usually breaks:
Motor vehicle Wheel Automotive tire Bicycle tire Tread
This is where the hoses lead, the 2 large valves at the top side of the picture:
Motor vehicle Automotive tire Auto part Automotive wheel system Engineering
In case you’re disoriented, start on the bottom picture. That is looking at the engine brom the back and below. The combi valves are those oil can looking things up on the backs of the cylinder head. When you hunch over from the top, you can follow the vacuum tubes that connect to them.
Discussion Starter · #13 · (Edited)
@PZ and @Hirnbeiss
Thanks for the pics and guidance.
I take it the lines I circled in red are the vacuum lines and the 2 devices I highlighted in green below are the solenoid valves? Is the blue item I circled the check valve?
Motor vehicle Automotive tire Automotive exterior Automotive air manifold Auto part
The two items in the picture below circled in red are the combi valves?
Motor vehicle Automotive tire Auto part Gas Nut
· Moderator/Administrator
Yes
Discussion Starter · #15 ·
Cool. It looks like the VW vacuum hose replacement kit is hard to get.
I'll have to buy the parts piece meal. How much of the vacuum hose do I need? In searching, the kit from ECS or FCP I think had a 1 meter long hose. Is that sufficient? I read that there is a hose that also goes to a "blue tank" on the driver's side that should be replaced? So that would easily be more than 1 meter in total. Perhaps 3 or 4?
I'll be taking a look at the car later on today.
Discussion Starter · #16 · (Edited)
Well, I looked and I broke something.... Dang it.
I was pulling on the hose circled in red to see where it ran down the front of the right cylinder back and the plastic hose broke and I heard a vacuum sound....
The line starts at the top, circled in red in the picture below:
Coil Gas Auto part Nut Composite material
In the picture below, top left you can barely see the blue of the connector to the right solenoid. The line is circled in red below. Bottom right of picture is where the line snakes down in front of the valve cover. The blue arrow is the direction I was pulling the line when it broke.
Motor vehicle Automotive design Electrical wiring Automotive exterior Automotive fuel system
Below is another picture of the line in front of the right front valve cover. The left black part is the timing belt cover.
Automotive tire Motor vehicle Gas Electrical wiring Auto part
In the picture below, the line connected way back up to the solenoid is circled in red. The rest of the line, where the break occurred, is circled in blue.
Hood Automotive lighting Motor vehicle Automotive tire Vehicle
When it snapped, I heard a hissing sound, I guess the vacuum being filled? I guess this is where the line may have been cracked causing my CEL??? I'm not sure where this connects to? I assume this is not part of the 3.5mm vacuum line?
I assume that it's still okay to drive?
Help please...
Discussion Starter · #17 ·
Doing research. I guess that's the line that goes to the vacuum reservoir. Now I need to figure out what size plastic line and silicone line I need to replace that. Also, guess I might to remove the left front fender to get to it? Wondering if that's the cause of my CEL...
· If I See a Problem I Tell Someone
Can anyone tell me if the vacuum line to the vacuum reservoir on the 2005 V6 can be replaced with the wheel well cover removed or do I have to remove the fender?
You don't need to remove either.
· PassatWorld Elder
I used about 10' of 3.5mm vacuum line to replace all of the plastic lines and vacuum lines on a V6. The vacuum line to the reservoir can be patched with a short section of vacuum line if need be. The hardest line is the one to the front of the variable intake actuator.
1 - 20 of 32 Posts
