1 - 10 of 10 Posts
So, it's time to replace the exhaust on the Brick - resonator is rusted thru, and the hole is growing. :(
Bosal is cheap, yes - but, also (usually) mild steel, and that stuff doesn't live very long in Michigan.
Walker resonator + muffler (aluminized, I think? pipes) is ~$375 from Rock Auto. I know it'll sound & fit like stock.
TT aluminized system (w/ Magnaflow stainless muffler) is $355. This is cheaper, and a bunch lighter (no resonator.)
My question to the collective: Has anyone run the Techtonics exhaust? How's the sound - livable for a daily-driven family hauler (read: Wife Acceptance Factor is favorable)?
I'm (generally) not opposed to a hearty exhaust (see: Scirocco 16v, TT/Borla exhaust), but, on the wagon, I don't want to hear the exhaust at every dividing wall or passing shrubbery.....
Hopefully someone with a Techtonics-equipped 1.8T can comment. My only marginally relevant experience is that I once owned a turbocharged/water injected Datsun 510 with a single "Corvair Turbo" muffler, no resonator, and the sound was very mellow, because the turbine damps the high-frequencies pretty nicely. You might also ask at VWVortex, which seems to be more of a modifier's site than PassatWorld.
Does Techtonics have any user's comments or videos to give you an idea?
That's why every summer I apply high-temp paint on the entire exhaust system and after 17 years it has no rust at all even with huge amount of salt on Michigan roads.
let us 1.8 owners from the rust belt know what you get and fitment issues if any..........rusting away here in Ohio,thanks in advance Chief
Emry, great idea! I just may start doing that myself as we have similar issue in Minnesota.TomK
If you choose doing that, just buy high-temperature spray can (silver) from Walmart ($4). Sand and clean and then apply 2 coats and you are good to go.:thumbup:
TT should also sell a resonated version (that's actually what the picture shows) that would be better choice for your wife. I had one person with a TT non-res setup and I could hear him coming from over a block away.
High (>180K) mileage - go with aluminized and clean/paint every 2 yrs or more often.
Low (<140K) mileage - get the TT stainless with a resonator.
If mileage is in between, flip a coin and hope for the best.
Discussion Starter · #9 ·
Yeah, I missed that in the picture. Description doesn't note it, and it's easy to overlook the bulge of the resonator.
Still, notes of first-hand experience from others would be appreciated, before I pull the trigger on it.... :)
How about this: When I heard my friend coming over, my 1st thought was "Who is that in the Honda with a fart can?"
1 - 10 of 10 Posts
