1 - 2 of 2 Posts
Hi guys!
I have a little problem with my Passat 2004.
When i drive , after around 5 minutes the ESP light turns on on the dashboard. And when I press the ESP button it doesn't help. The button is dead, I can't neither turn the ESP on or off by pressing the ESP button.
When I scan the car via VAG, code 00526 comes up. I have replaced the brake switch light but the fault code won't vanish and I can't still switch the ESP manually on or off, and I still get the ESP light on the dashboard after driving for around 5 minutes.
The tires are new and same recommended size.
I have tried to erase the code but it comes back. Even tried to press the brake pedal before searching for codes but it didn't help.
I hope you guys can help me!
Thank you so much
Donche
1 - 2 of 2 Posts
