1 - 17 of 17 Posts
Hello All,
Looking for some assistance with the following codes. They may not all relate to the EPC light being on, but I would like to resolve the light related things first.
System description: 1.8L R4/5VT G
Software number: 4B0906018CM
Software version: 0010
Hardware number: 8E0909018
Coding: 0016551
Trouble codes:
P0322 - Ign./Distributor Eng.Speed Inp.Circ. No Signal No signal/communication
Intermittent
P0300 - Random/Multiple Cylinder Misfire Detected Implausible signal
Intermittent
P1114 - Bank 1, sensor 2 Internal resistance too high Implausible signal
Intermittent
P0304 - Cyl.4 Misfire Detected Implausible signal
Intermittent
P0140 - O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected No signal/communication
Intermittent
P1479 - Brake vacuum system mechanical malfunction Implausible signal
static
P1556 - Charge press. ctrl. Value below lower control limit Lower limit not reached
Intermittent
P1327 - Knock control cylinder 3 Control limit reached Upper limit exceeded
Intermittent
P1328 - Knock control cylinder 4 Control limit reached Upper limit exceeded
Intermittent
P0012 - A Camshaft Position (Bank1) Timing over-retarded Upper limit exceeded
Intermittent
P1250 - Fuel level too low Implausible signal
static
Any help and guidance would be greatly appreciated.
Miles2Go
· Moderator/Administrator
When was the last time you scanned for codes? Some of those may be old stored codes.
What are your symptoms?
This scan was taken about 2 weeks ago, when the EPC light came on and the car shut off. Here is my scan from today:
OBDeleven data log
Date: 2023-02-24 16:17
VIN:
Car: Volkswagen Passat
Year: 2002
Body type: Saloon
Engine: AWM 125 kW (170 HP) 1.8 l
Mileage: 311700 KM
01 Engine
Coding: 0016551
Trouble codes:
static
P1326 - Knock control cylinder 2 Control limit reached Upper limit exceeded
Intermittent
Intermittent
P0011 - A Camshaft Position (Bank1) Timing over-advanced or System Performance Lower limit not reached
Intermittent
Intermittent
Intermittent
Intermittent
static
P0333 - Knock Sensor 2 Circ. High Input Upper limit exceeded
Intermittent
P0328 - Knock Sensor 1 Circ. High Input Upper limit exceeded
Intermittent
Yes. That is what i was going to suggest.
Any current symptoms?
Reactions: AndreasPassat
Discussion Starter · #9 ·
Replaced the crankshaft position sensor, but while doing so, broke the t fitting for the vacumn lines under manifold 🤐. I assume it's just a normal t. What is the best way to get the remnants out of the tubing? Any idea what size t i should get?
· PassatWorld Elder
You can try a wood or sheet metal screw to get the broken plastic tube out of the hose. Most auto parts stores will carry a package of plastic fittings. I know AutoZone has one that worked.
You would need about a 3.5mm fitting.
If the plastic tube doesn't come out with a screw inside, you can just crush it with pliers and pull out the broken pieces.
Great suggestion. I ended up just replacing the connected hoses with 5/16 ID heater hose and advance auto had the tee. Everything back together and took a drive to Maryland (60 miles round-trip). Ran ok, but still lack of power, in my opinion, particularly at wot. Will look to do a smoke test and look to the turbo next. Thanks for all the assistance. I'll be back with another thread 🤪
1 - 17 of 17 Posts
