I drove about 200 miles after fixing my melted AC switch (details here) which was caused by squished wires from a thermostat and timing belt job after the car overheated. Everything worked fine.
Then the EPC light came there was a loss of power. Took a bit and was able to re-start and get home. Then a few days later I tried again and EPC came on again.
I scanned the codes and the only stored code is P0118. This seems like it means the ECT sensor is not working.
For the AC switch repair I disconnected and reconnected a bunch of wiring harnesses including T14k, T15k, and all the center stack. Is it possible that something is loose from that and causing issues?
