Check engine light is on and dash says "Emission Workshop!". I've been told it could just be a leaky gas cap causing the warning. If it is the cap and I replace it, will the check engine light reset itself or does it have to be reset by the dealer?
Thanks Trekie - it was the vacuum lines - had them replaced today.Trekie said:Just make sure you hear at least 3 clicks when you close your gas cap. Also check your vaccum lines.
