i dont know who i pissed off above, but just when we get 2ft of snow and cold temps...BAM! overnight:
keep in mind this is for a B5 Audi A4, very similar electrical system:
What doesnt work:
-no heat, the blower isnt working. but the console is.
-no turn signals, but parking lights work
-no fogs
-no boost gauge lighting (directly wired to 75x)
-no wipers
At first i thought maybe the nut came off the 75X post, no luck, i dropped the knee bolster at lunch, everything is secure. Also I checked every fuse 25Amp and greater, even the 40 and 50 under the relays. all are ok.
What works:
-HEATED seats, thank god.
-interior lights
-stereo works
-hi and lows beams
i plan on checking the ECU box, is there a relay for the switched power (75x)?
THANK YOU FOR YOUR HELP! :thumbup:
Discussion Starter #2
update - other gurus seems to think its the load reduction relay or ignition switch...and idea which relay it is?
ignition switch, had the same exact problem
if you had a volt meter on your car you would also notice a low reading at startup and until you reved the engin/started driving.
thanks for the inputs...im off to get another relay to try that, if its the ignition switch, what kind of job is that? easy? thanks!
