So I have been experiencing some weird stuff... It started with my instrument cluster turning off intermittently. Now my car won't even start. I had an old instrument cluster laying around that I tried with the same result. Take a look at the video below.
Does anybody have an idea of what this could be? Bad ground? I have replaced half of the relays and checked every single fuse...
Corroded wire splices under the carpet going to the CCM, or maybe the CCM itself is wet.
Edit: now that I watched your video, I was thinking it might be your battery or grounds.
Bad batteries (usually with a dead cell) can cause some weird electrical issues, so have it tested.
I've had the ignition switch kill the cluster with a no-start condition, but it was either on or off, not the light show you have.
The battery is only a few weeks old. I am out of town for a few days, but will be back to check in a few days. Any idea what ground it could be or where they all are?
To give you guys an update: I was poking around with my multimeter when I saw that one of the ground bolts under the dash was loose for some reason... After tightening it, it started right up and I haven't noticed anything weird since! Crossing my fingers that it won't start acting up again. If so, I can't believe how little it takes before nothing works lol :icon_eek:
