Does anyone know the correct size torx driver for the bolts/screws on the metal box containing the board/ecu? I am referring to the metal box that is insde the black platic box located on the driver's side inner firewall.
If it matters, mine is a 2003 Passat with ecu part #4B0 906 018 DA.
Thanks.
scotty_passat,
Yes, those are the ones. Thanks.
I don't need to open it now. However, I recently had a Wett chip installed and want to carry the OE chip and tools need to switch back to the OE chip in the car in case of need.
Retired PassatWorld Staff
You should have a 10mm hex for the weather proof ECU cabinet. A T-15 as mentioned above for the ECU case, and then a small flathead screwdriver is handy to release the spring clip that holds the ECU in it's nest.
pass-variant,
Yes, I already have a small ratchet drive with the appropriate socket for the black vinyl box, and a screwdrive for the spring clip. I just didn't want to have to take that apart again just to figure out which torx drive size was required for the inner box.
Thanks nonetheless.
About this Discussion
3 Participants
Slider
Volkswagen Passat Forum
Passatworld is a forum dedicated to Volkswagen Passat enthusiasts to discuss mods, Quattro, Turbo Diesel, reviews and more!
Full Forum Listing
