Click HERE to order or for more information.
Motive Brake Bleeding Products -
Are you ready to make your fluid bleeding job as simple as changing your oil? Typically, two people are needed in order to get the job done, but sometimes, that second person isn't around and when they are, the job itself is extremely time consuming. These new Motive products will make a complex job an easy one. When it comes to bleeding your brakes, you won't have to pump the pedal. This tool uses pressurized brake fluid to force air and old fluid out of your brake lines. The same can be said for clutch and differential fluid. Make your vehicle's service easier with these products.
