1 - 9 of 9 Posts
The TT DV I ordered arrived today so I plan to install it this weekend. On a whim, I also bought the small clip PN: N10091101 which fits the smallest of the three hoses. I figure I'd just get regular hose clamps for the other two.
The small clip is the "one time use" type. I cannot figure out how to tighten it.
Anyone with prior experience able to explain how it tightens?
Scuba2001,
Thanks for the heads up. I will just use standard clamps all the way around.
Regarding removal of the existing one-time clamps, what type of tool do you recommend for cutting them off?
You have to use some crimping pliers to tighten it. Almost like a pair of wire cutters, but not sharp.
I'm replacing mine this weekend too along with the vacuum line. Should be fun.
not_to_shabby...
I think I have crimping pliers, I'll have to see whether mine will work. Do you already have removable hose clamps and if not, what will you use to remove the OE one-time-use clamps?
On the Wurth-type clamps, I've been able to cut 'em at the crimp using standard diagonals but it takes both hands.
Are these like a screw-type clamp? In the past, I didn't have any luck sourcing screw-type replacement clamps for 3.xmm lines, so ended up buying the same Wurths from an indie for $1.50 each and crimping them using end nippers.
Where did you get these from?
You can just pull the vacuum hose off the little nipple on the DV more than likely. The bigger one time use clamp I had to cut off. I have already replaced my DV once. I'm replacing it again cuz I'll be under there anyways.
Yeah, you probably won't find small screw type clamps for the vacuum hose. I have actually been able to reuse most of those small one time use clamps by just prying the crimped part apart and clamping it again.
@Slider - you may not want to use a normal clip on the vac line, either - it's so small that the screw housing distorts the clip from round, possibly leading to a leak. Try the smallest cable tie (zip tie) you can find, and only pull it snug tight. Remember, it's a vac line - it's not trying to pop off the nipple, anyway.
I really recommend swapping out the OEM vac line for a silicone vac hose - you're already working in the same area. Just tape the end of the new hose to the end of the old hose and draw the new hose through. Good luck.
1 - 9 of 9 Posts
