1 - 1 of 1 Posts
Could be the motor or regulator. Also, OEM Passat regulator clips are notorious for breaking - weak design. Many here have replaced with beefed up aftermarket clips. It could have jammed up your regulator, and your motor is encountering too much resistance.
Before you rip everything apart, I assume you've tried to push down on the window while engaging the switch (probably requires two people)? I've seen on other models where grime/dirt, dirty track, and not opening the window for a long time can cause too much resistance.
1 - 1 of 1 Posts
