1 - 3 of 3 Posts
The driver door on my 99 is having some problems knowing if it is open or closed. When it's closed sometimes the lights stay on and the chime keeps chiming and when open the lights won't come on and no chiming. It seems as if the door pin is not working properly but when I look for one I can't find it. Where is the switch that tells the car if the door is open or closed? If I can find the switch I should be able to fix the problem. All the other doors are fine so I doubt it is a CCM issue.
Thanks for you help.
1 - 3 of 3 Posts
