Ok, so all my doors have this happening now, where they don't open on the first pull (mostly after initially unlocking). I know how each door has to reset back to its original position before the door can be re-opened, and about the indexed cable on the outer door handle, and have played with that length to try to fix. I also read about lubing the latch and catch with some dry lube - I decided to try Boeshield.
Here's the problem - when I got to my driver's door, I noticed that the rubber covering over the metal latch (that is the exposed part of the locking mechanism) was starting to seriously corrode. Basically, it could jam up the latch at any time, and prevent the door from ever opening. So, the only decision I saw was to immediately remove the regulator panel and lock mechanism, because the door will likely soon never open again. I have everything out (a total nightmare, as you all know), but I don't know if there's any way to replace just that metal latch by taking apart the lock mechanism, or if I'm going to have to fork out $100s for a whole new lock mechanism.
I'd also like to know if anyone has lubed the internals of the lock mechanism, and where, with what, to also address the sticky door syndrome.
EDIT: BTW, I've done at least one door microswitch re-soldering (I think on this door), so I'm familiar with and comfortable pulling apart the lock mechanism, if there's some way to salvage or replace just the latch.
