As the topic says, I changed the break pads last night, and the break feels like need to be bleeded. Is this normal? Should I give it couple more days for the pads to break in?
Thanks,
You only need to bleed them if you apened the line. Otherwise it should be fine. I would abserve the break-in instructions from the manufacturer. Sometimes it takes a little bit of time to get them to bite. Also, do you clean off the rotors with a brake cleaner. It is easy to get oil and grease on them during the process.
You dont NEED to bleed them but you SHOULD bleed them once every two years.
Brake fluid is hydroscopic and absorbes water over time, reducing its wet boiling point. I know folks that never bleed, but its just a good maintainence procedure that if you have the time and skill, wont hurt and would help.
Right, you actually should flush the entire system of fluid every 2 years..
Fluid is hyGroscopic, not hyDroscopic. :)
DOH! :shock:
hy·dro·scope n. , hydro·scopic adj.
An optical device used for viewing objects far below the surface of water.
hy·gro·scop·ic adj.
Readily absorbing moisture, as from the atmosphere.
Ok, fine... would you believe I own a submersable B5? :oops:
MikekiM makes a good point here... "entire system" and since the clutch shares the resevoir it should be flushed/bled as well. (Which by the way I do not know the correct sequence, but I have done it as the last item after all the wheel cyl. were done ! ?
