I know some spring makers do no advise cutting bump stops, but if you are lowered, cut bump stops make for a smoother ride. My sedan was .25" lower after the bump stops were cut, so it was riding on them with only a 1.5" drop.
Stock front bump stop:
Twist and pull apart:
Rubber bump stop with dust boot removed:
Cut through 2nd valley from top with a hacksaw:
Short stop :)
Trim bottom close to valley, leaving just enough to hold the dust boot:
Use spray lube and twist/push back into dust boot (use less lube than I did, it splatters):
Finished bump stop:
Thanks to my wife for taking pics.
Discussion Starter #2
Updating the pics:
98051
98052
98053
98054
98055
98056
The rest of them:
98058
98059
98060
