So I looked behind the fuses and I see a relay labelled 373. There is no label "173". Is this the correct relay to pull to disable the DRL's?
Whoa - it's pin B and 56D for B5.5 or TFL for B5 I believe.citispot said:Tape pin 156.
Oops, you're right. Actually, I didn't tape pin B. I just taped 56D and it works fine.RL331 said:Whoa - it's pin B and 56D for B5.5 or TFL for B5 I believe.citispot said:Tape pin 156.
