Not sure if anyone noticed, I was thinking if theres a way to reverse the stock day time running lights (projector lights) to using city lights as the day time running lights? That way when the switched is flipped, the main projector would turn on.....I think this is more logical since the city light is much more dimmer and uses less power to be running all the time and the main projector can be turned on at night by driver...?
Just pull relay 173 and use your headlights as you see fit. City lights as your pseudo-DRL's and then headlights as intended.
so by pulling relay 173 to disable to projectors lights and let it controlled via Euroswitch? Will city lights stay on as DRL's when engine is turned on?
I had a 330 before and that's how the lights worked, normal DRL is the dimmer city lights, at night, you can turn on the projector Xenons....I like that set up..
