1 - 20 of 22 Posts
After reading various posts as to the relative usefullness of the rear speakers, I came up with a rather interesting idea. Feel free to laugh!
My ultimate plan is to replace the monsoon amp with a separate 4 ch amp for the front and rear comps and then add a second amp for the sub.
Currenly I have only replaced the tweets in the front and kept the mid-woofers in. I have a feeling that replacing the stock 2 ohm mid-woofs with 4 ohm ones and then driving them with the Monsoon amp (even if only temporarily as I install the new amp) will be less than desireable as the Monsoon amp won't be able to push them well.
But I was thinking of just replacing the tweets in the rear and leaving the rears intack with the Monsoon amp. Then drive the new front comps with a new amp as well as a sub.
Of course this completely eliminates any possibility of adding an equalizer... but considering how those rear speakers have thier bass boosted by the Monsoon amp... I was thinking it might sound pretty nice.
So you want to continue to run the rears off the Monsoon and get a 3-channel amp for the fronts and sub? There's got to be a 3-channel with independent gains on it to eliminate the need for that adapter.
Discussion Starter · #6 ·
StLB5 said:
Did you order the 4-ohm sub?
It's on the way! At least they said it would be as of tomorrow.
StLB5 said:
Another question, whats the difference between a 3-channel amp and a 4-channel running one side bridged?
Is that supposed to be a riddle?? LOL
Actually makes more sense to buy a 4 ch amp to use in this way. And then get another 2 ch amp for the rear someday.
Gives me more flexibility for the future since every amp I every amp I have even purchased is functioning fine. (Including a 22 yr old ADS (when they were ADS, not a/d/s ) Power Plate that drives the sub in the back of my Golf.) In fact, once the Golf does die that amp could power the rear comp in the Passat.
I'd get a 4 channel amp and bridge 2 channels to give yourself more power. You can get tons of power out of an amp that way. Remember that more power means clearer sound at all volume levels.
so you have a 4-ohm 10w3v2 going in the back, what components are you looking at? Just a guess, but something that handles 100watts would work well. That way you can get a 100X4 amp to feed 100 to each of your fronts and 400 to the sub.
Discussion Starter · #9 ·
I have a pair (actually 2) CDT Audio HD-62/CF's. I think they are rated at 90 w/RMS. Going with a 100x 4 is probably okay.
Discussion Starter · #17 ·
Discussion Starter · #18 ·
Was thinking about this whole idea and realized that the results would probably be disappointing. No doubt the front comps and the sub would sound great.. but I would probably have trouble balancing the rear with the whole setup. In other words, the Monsoon amp will be so underpowered compared to the rest of the system that I won't hear it at all.
So I guess I am probably back to plan "A".. a four channel amp for the front and rear and then a 2 ch bridgeable amp for the sub
1 - 20 of 22 Posts
